This is question 19819
You want to turn right at this intersection.
You slow down and, if necessary, you stop to give way to …
A. All road users.
B. All drivers.
Wrong
Correct = C
LESSON 19
The priority sign indicates that you must give way to drivers on the crossing road.
If necessary, stop before the inverted triangles on the road surface, also called shark’s teeth.
C is not an option. The correct answer should be B
Question 19819
Re: Question 19819
B All drivers
