LESSON 15: OVERTAKING ON THE LEFT
Arun03
Bericht door Arun03 »
question no 8212
This is question 8212
Is the blue car allowed to overtake these two cars at the same time on the left on this
The answer should ideally be yes as per the explanation given in chapter 15 (highlighted below) but if we select yes as the answer the system marks it as wrong answer.
Normal lane (1x1) If you are driving on a normal lane (1x1), you must return to the right lane after overtaking the first vehicle, if this is possible without objection, before you start to overtake the second vehicle. Suppose: a car is driving in front of you and another car is driving 50 meters in front of that car. If you have overtaken the car in front of you, you must first return to the right lane before overtaking the second car. But if those two cars were to drive very close behind each other, so that it would be dangerous to turn right immediately after overtaking the first, then you can overtake them both on the left.
Could someone shed some light on this..?
Re: LESSON 15: OVERTAKING ON THE LEFT
That's weird as you're allowed to overtake 2 vehicles at once ...
GRO :?:
Missing.
YES
