Can I drop off a friend in the bus specific reserved route ?
What should I do if I see a flashing yellow light when prority in the next intersection on the road? should I stop or drive on?
questions in the exam
Re: questions in the exam
You may not drive in a bus lane or reserved bus route to drop off / pick up someone, nor to (un)load goods.
Flashing yellow light ahead of an intersection indicates a warningWhat should I do if I see a flashing yellow light when prority in the next intersection on the road? should I stop or drive on?
Usually it's always on (well, on and off, and on and off ...
Sometimes it only starts flashing when the light @ the intersection turns orange or red
A single, separate flashing orange light (or a bi-flash) at an intersection will also be a warning
Flashing yellow-orange lights in the regular traffic signs at the intersection
Occasionally you'll see the green replaced by blinking orange, that's a warning as well
The lights will go on to steady orange, then red, then blinking orange again (meaning "green with caution")
But usually it means the traffic lights are out of order and the signed priority is applicable
No signed priority -> priority from the right
