Question number 8820
s.s.mehta7658
Bericht door s.s.mehta7658 »
How can the car park on a raised verge within a built-up area?
The rule says in a built up area you cannot park on a raised verge
Re: Question number 8820
The rule says in a built up area you cannot park on a raised verge.
So answer A is correct.
s.s.mehta7658
But in the answer it's given C - He must park.
GRO schreef: 14 feb 2019, 03:01 The rule says in a built up area you cannot park on a raised verge.
The rule does not say so much that you cannot park on an elevated roadside in built-up areas, but rather that you have to park on an equal ground roadside if there is one. This is not meant to contradict you, it is only a slightly different view.
Answer A is indeed correct. But until yesterday, the site stated that answer C was correct. This explains why the questioner does not understand your answer.
