What is the rule with the order of the signs when they are on top of the other? In this question the 100m plate is under both the danger sign and the max speed limit of 50kph. I thought that this 100m would affect both (it wouldnt make sense of course to say that in 100m there is a level crossing and then you are allowed to drive 50kph...) But still what is the logic? The speed limit is always conditioned by a danger sign ; OR is it becuase of the order of which sign comes on top?
Thank you in advance!
Q. 8532
Re: Q. 8532
The blue/white undersigns only apply to the main sign directly above
There is no regulation whatsoever that 1 undersign could apply to multiple signs above it
Though in many cases, that is what is meant by the road authority, but improperly indicated ...
If you look around, you'll see a lot of speed limits combined with a danger sign, but ...The speed limit is always conditioned by a danger sign ;
It is actually illegal to combine a danger sign with a speed limit
It is even illegal to use a speed limit where a danger sign may be used instead
The sole allowed exception is the school zone, combining
