I am practicing the full exams but every time I am failing on this topic question. I think the answer provides are not right.
Fo example
This combination of signs indicates, it is prohibited to turn left for drivers of vehicles …
A. ... with a M.G.W. of more than 3.5 ton.
B. ... with a M.A.W. of more than 3.5 ton.
Answer: It should be B but it is giving the correct answer A
In case of 5 ton question
What does this sign indicate?
A. The M.G.W.
B. The M.A.W.
Answer: It shows that the B is the correct answer.
Why the rule is different for 3.5ton
M.A.W. AND M.G.W.
Re: M.A.W. AND M.G.W.
We cannot help you if you don't write yhe number of the question
