Question 8237,
Question: If you want to overtake this cyclist on the left, you have to leave a safe space in between of 1,5 meter.- Answer is Yes
Chapter 15 (page 92) mentions that when overtaking pedestrian, cyclist, 2-wheel moped, lateral distance should be 1 meter.
So the answer is 1 meter or 1.5 meter?
Thanks,
Amit
Question 8237 (Overtaking on the left)
Re: Question 8237 (Overtaking on the left)
It depends wether you're in or outside a built-up area (again, since May 31, 2019 )
Inside built-up area: 1 meters
Outside built-up area: 1,5 meters
The question will be updated to make the difference more clear
Oops!
Is there a way whereby all the drivers get notified of these changes? I mean lot of things keep changing.
By the way, thanks a lot Rafael once again!
Regards,
Amit
Regards,
Amit
I can only link you to the changes in Dutch at this moment. I think the author of the book will update the 'updates page' on the website of the English book soon, but can't really confirm at this moment.
Thanks a lot Rafael!
Amit
Amit
The sheer number of changes to traffic regulation, is a big issue in Belgium ...amitbhavsar85 schreef: ↑01 jun 2019, 19:17 Is there a way whereby all the drivers get notified of these changes? I mean lot of things keep changing.
But no-one gets "officially" notified
You have to read it in the papers, which often give wrong information ... oops
Or on specialised websites that virtually no-one reads ...
hmm! This is awful!
And I take the test and the lateral distance that one must keep while overtaking a pedestrian is 5 point question. I just hope that it is not 3rd or 4th degree violation!
Amit
Amit
Only passing less than 1m is a 3rd degree violationamitbhavsar85 schreef: ↑03 jun 2019, 12:51 hmm! This is awful!
The legislation to change that to 1.5m wasn't done.
The rule of the road, and the severity of the infractions, are 2 different sets of regulation ...
The text of the decree regulating the severity takes precedence over the text of the rules ...
Passing a pedestrian (Art 40.7) is a non-graded infraction, i.e. a 1st degree one
