Hello,
Its regarding the question 8418. There is Traffic Sign (STOP) right before(5 to 10 meters) the Traffic Signal.
Driver is in front of SIGN and the signal is green & he wants to turn right.
Question is whether the driver has to stop or not?
As the Traffic Sign is placed before the Light , isn't the driver has to give more attention to SIGN then Lights.
Please suggest.
Question - 8418
Re: Question - 8418
If the functioning tricolour traffic lights and the sign are applicable to the same traffic situation, then the traffic light has priority over the priority sign.ctspandey@gmail.com schreef: ↑30 jan 2020, 12:39 Its regarding the question 8418. There is Traffic Sign (STOP) right before(5 to 10 meters) the Traffic Signal.
So you don't have to obey the STOP sign when it's green
Lights & signs aren't always placed in the same position
- Contacteer:
Re: Question - 8418
You don't have to stop when you turn right, but still you must give way to the traffic on the main road.
You want to turn right.
Do you have to stop first, before you cross the junction?
Re: Question - 8418
Which is not a result of the STOP signde rijprof schreef: ↑31 jan 2020, 00:35You don't have to stop when you turn right, but still you must give way to the traffic on the main road.
But because of the combination of a red light with an additional green arrow (integrated in the light as in the pic, or mounted to the side of it)
Traffic may proceed in the green indicated direction, but must give way to other vehicles AND pedestrians
Re: Question - 8418
Thanks for your response.
Well my Theory lesson teacher is having a different view which stays that I have to stop .
I am wishing I should not get this question in my exam
I will consider it NO for now.
Thanks
Thanks
Re: Question - 8418
Your theory teacher is wrong I'm afraid.Gast schreef: ↑31 jan 2020, 16:35 Well my Theory lesson teacher is having a different view which stays that I have to stop .
The traffic lights are working at the intersection
Which means the priority signs are not applicable - in accordance Art 6.3 first alinea:
https://wegcode.be/wetteksten/secties/k ... e/105-art6
6.3. Als de verkeerslichten op een bepaalde plaats werken gelden hier de verkeersborden betreffende de voorrang niet die op dezelfde weg geplaatst zijn.
(the second alinea contains a few exceptions to that, mostly on behalf of cyclists)
You still have to yield to other traffic though
If the light doesn't work - meaning a blinking central amber light-
Or if the bottom light is an amber blinking light instead of green, then he'd be right and you'd have to obey the priority signs ...
Print & show
- Contacteer:
Re: Question - 8418
Make sure you make the difference between this type with several arrows
Where you schould have priority.
Or...
This type with only 1 additional arrow
Where you don't have priority.
Or...
Re: Question - 8418
There is NO LEGAL REQUIREMENT that anyone following tricolour arrow-shaped traffic lights, should have priority over traffic coming the opposite wayde rijprof schreef: ↑01 feb 2020, 11:54 Make sure you make the difference between this type with several arrows
Where you should have priority.
So please stop pretending that it exists
It doesn't
Cross-traffic obviously should have a red light when you have a green arrow in the tricolour system
Which is a legal requirement after all.
But that legal requirement is being ignored by the road authority at ever more crossroads in Belgium (mainly Flanders)
- Contacteer:
Re: Question - 8418
Indeed, 'should' have, don't take this always for granted, so be carefull.
