question 10883
question 10883
The question asks "do you have priority". If i am the one seeing such sign, it means that I do not have priority, therefore that i must give priority to the right, right?
So why is it wrong if I selected "no"?
The system shows that the correct answer is "A. Yes, for every driver from the right."
Re: question 10883
Bericht door Rafael »
You're right, if you can see the sign, you should give priority to the right.
@GRO Can you check this question?
