Confused about priorty for reduction lanes
Mohammed Ahmed
Bericht door Mohammed Ahmed »
When there is a reduction lane, there are two cases:
1- When the reduction lane is on the right, the driver on the freeway has to give priority.
2- When the reduction lane is on the left, the driver on the freeway has priority.
is this correct?
Re: Confused about priorty for reduction lanes
Partly ...
This is in the condition that there's no traffic jam (traffic pace is not severely reduced)
If the driver in right lane is forced by road signs to merge into the lane to the left, he follows the right side of the road and thus enjoys priority from the right (as that is the normal priority rule ...).
If the obstruction is a parked or waiting car or so, the driver in the right lane would do a manoeuvre when merging into the left lane, and has to yield ...
You know that Paul Simon song, "50 ways to leave your lover" ?
Belgium has 50 ways to leave your lane ...
Mohammed Ahmed
Thank you for your response.
The example you mentioned applies well in 'zipping_provedided that lanes are there': meaning that when the obstruction is on the right: the right car has priority. And if the obstruction is on the left, the left car has priority on the expense of the car in the free way
but taking another example as F97 sign:
when the reduction lane is on the right: the right car has priority.
when the reduction lane is on the left: the left cat has NO priority.
I am correct?
Thanks
Mohammed Ahmed schreef: 03 mar 2019, 00:08 The example you mentioned applies well in 'zipping_provedided that lanes are there': meaning that when the obstruction is on the right: the right car has priority. And if the obstruction is on the left, the left car has priority on the expense of the car in the free way
If it's some physical obstruction other than traffic signs that force you into the other lane, it doesn't matter which lane you're moving out from: you have to yield as you're changing lanes.
That changes if and when traffic slows down to a crawl ("sterk vertraagd verkeer") in both lanes: then you have to zip.
F97s are normally used along with road markings that push you out of either lane (the edge of the road marking, lane reduction arrows)
If you follow the right side of the road, you have priority - just don't expect to always get it ...
So you have 4 situations leading to lane reduction
- traffic signs including road markings :arrow: apply priority from the right
- some undefined unsigned obstruction :arrow: yield when you're changing lanes
- either of the above combined with crawling traffic: zip
When politicians were looking to get the zipping-rule into the traffic laws, I've tried to put it out of their heads as they'd make an already complicated situation even more clouded.
They wouldn't listen ...
