Bus priority
dhanraj
Bus priority
Bericht door dhanraj » 15 dec 2018, 12:35
I have a question. Consider a Bus which is leaving a bus stop. I am with a car behind the bus.
1. What to do inside a Built up area, when No indicator of the bus is on? - I give priotiy to bus?
2. What to do outside a Built up area, when No indicator of the bus is on? - I do not give priority to bus?
3. What to do inside a Built up area, when the indicator of the bus is on? - I give priotiy to bus?
4. What to do outside a Built up area, when the indicator of the bus is on? - I do not give priority to bus?
Thanks for the time
Groetjes,
Dnu
Re: Bus priority
Bericht door Jozef » 15 dec 2018, 12:58
dhanraj schreef:
15 dec 2018, 12:35
You don't have to give priority to the bus. If the bus driver nonetheless tries to leave the bus stop, use your car's horn to warn him, but slow down and keep ready to brake, so if necessary, you can avoid an accident.
Yes, you do, if the bus is providing a regular service (not for instance when it is used for an exceptional service, for driver's education or when it is driving to a depot).
dhanraj
Re: Bus priority
Bericht door dhanraj » 15 dec 2018, 17:48
Yes, I understand it now. Reasonable explanation
Thanks again
Groetjes,
Dnu
