Hello Team,
I am referring GRO book.
Question: lesson 19, question 28.
Correct answer: Yes
My question: It is not written in the book that what we have to do when entering and leaving when it is not a roundabout.
Could you please tell me what we have to do in this case.( both case: entering and leaving when it is not a roundabout)
Regards,
GRO: Lesson 19, Question 28: Its not a roundabout
Re: GRO: Lesson 19, Question 28: Its not a roundabout
Use your indicators
Both are a directional change, to the right
You have to note the real number of the question.Question: lesson 19, question 28.
If it is not a roundabout, then it is an ordinary intersection. Use your indicators.
Thanks both for the reply. My question number is 8376.
Please correct me if I am wrong.
You meant, if it is not a roundabout then we have to switch on the indicator while changing the direction; So, in this example,we will switch on the indicator while leaving it.
Regards,
Regards,
If the place is not a roundabout, you have to use the indicators twice: once on the intersection with the road you are leaving (which is not mandatory on a roundabout), and once again on the intersection where you leave the place (which is also mandatory on an roundabout).Gast schreef: ↑25 mar 2018, 18:06 Thanks both for the reply. My question number is 8376.
Regards,
Please note that it is not sufficient to switch the indicators on while turning. You have to switch them on long enough in advance to make your intention clear to the other road users.
